I'm the time the car had been off the road, the centre latch (only on the pre facelift I understand) seems to be stuck in the open position. I've lubed it up and tried a quick jiggle with a knife and no luck.
Does anyone know how it's removed? There's 2 torx either side which I popped out but it's otherwise attached. There looks to be another 2 torx but access is obscured by the trim so didn't particularly want to pull it all apart if that's not going to get me access. Is it powered by the same more that controls the left/right catches or does it have its own little motor? I'd be inclined to delete it as the roof has never fully opened to flush without a little assistance, but guessing that would leave me with the flashing light?!
On the subject of the roof, is it normal for it not to want to stay half open? If I stop it in a 2/3 open position, it droops open more under its own weight, almost like there is an absence of hydraulic pressure?
