jayd1000 said:
Hi guys as above, my roof works fine but the buttons don't illuminate. Not a big problem but just wondering if there's a simple fix??
Do you have the Gaptech roof mod fitted? As I had the same problem a few months back, the roof dropped/raised correctly but the lights under the buttons did not light up. I removed the ash tray and the switch panel to check the wiring and found a green and black wire had been pulled out and reconnecting this fixed the problem so even if you haven't got the Gaptech fitted it may be worthwhile you checking this wire is connected/has power when raising lowering roof.
Good luck with your investigation
