Sorry, I know roof problems are done to death on here and I've been searching...
Motor is in the boot for two years (thanks no 5).
The roof operation is intermittent. Started slow and sticky at the start of the season. I spray lubed the hood mechanism and it worked ok.
Now sometimes it works, sometimes it doesn't. Sometimes it gets stuck. Sometimes the lights don't come on at all. At the moment nothing is working, no lights, nothing. Last night I closed it manually, locked it with Allen key, after which the open mechanism worked enough to unlock it again and then it died... no lights.
Fuses are ok. Red cable goodie in the boot sort of works but requires a lot of force and has no feel to it, could be partially seized? interlock microswith in boot shelf seems to be working ok.
What else should I be looking at? Thanks.
