Rheingold ISTA setup
rich48848
Anyone got any pointers on getting this going?
PDF says to modify obd.ini file but there isn't one in the Ediabas/bin folder.
I changed the Ediabas.ini from:
Interface = REMOTE
to
Interface = STD:ODB
My K+DCAN usb cable is sitting on Com1. Tried setting to Com9 too.
In INSTA I get this error:
IFH-0027: IFH NOT FOUND
Not sure what to try next?
Any advice welcome!
Have you tried setting it to STD:OMITEC you will need the omitec drivers for this to work though. Not sure it’s compatible with that specific cable but it works for me
Daft question.....
Have you tried searching all files for Ediabas.ini in case it's somewhere else?
skelters said:
Daft question.....
Not a daft question as I have two other Ediabas installs from putting DIS and INPA on this machine, so I will rename those folders to make sure....
I also noticed that in Ediabas.ini there are paths to the older installs...
