Reversing camera angle
That’s the one I have …yes the image is distorted but all you’re trying to do is see where everything is..as I found out to my cost..you can have say a pole which is in line with the rear wheel and with narrower angle camera it will be off field..
This is mine, it's supposed to be 170° (can't confirm). This is set up with the iDrive internal camera option, hence the picture in the smaller box, if used with an mmi box then it could be full width of the screen.
Here you go, same camera, two different mmi boxes (full width version is the current Mr12volt box) :thumbsup:
Do they work in the dark?
I can miss most things with the front & rear radar, but the lack of a rear reversing light is a real nuisance.
Mine doesn't really, until I press the brake pedal and it illuminates whatever is there. You can get cameras that have the infrared LED's around the lens that "should" help with nightvision, but I wouldn't rely on it.
Dave,
I wanted to ask, I ended up buying my parking camera yesterday, and have watched your video on your YT channel. I have the Mr12Volt MMI box already installed and working (although interestingly it looks like I always have to have the volume ‘on’ in order for it to work - or at least for CarPlay to display ).
My understanding is that the RCA cable will run from the reversing camera and present AHD720 to the MMI box which will display it on the idrive display and the MMI box will pick up reverse being selected from the canbus and then display the image from the camera. I assume the camera still needs to be powered so do you recommend powering off the reversing light or another source ?
Apologies if this may have been discussed before….
This is the one I ordered
https://www.amazon.co.uk/gp/product/B0CQQJJZZ4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
simnew said:
Dave,
Yes, if you press the volume button (mute all) it pauses what's playing (CD, USB), it also stops the Mr12volt box from displaying properly, this is normal :thumbsup:
You can power the camera from the reverse light, but i highly recommend using one of these...
https://www.amazon.co.uk/dp/B0CZ8M4JCP/?coliid=I2541WQDTGOV9H&colid=SHM7HC8GH0OG&psc=1&ref_=cm_sw_r_apann_lstpd_QJHD0CR9RT44G9WG6PBJ&language=en_US
Without this the image can glitch and stutter, this box smooths the power signal and steadies the image :thumbsup:
