Reverse camera on sat nav screen
mac27040
Shepshed
I am currently looking at adding a reverse camera to the pro sat nav / tv tuner system, to make it look factory fit not an aftermarket kit.
Items required:
Av input cable to tv tuner
http://bit.ly/JtWPNg
Reversing camera, various option available but you need a NTSC version unless you recode the tv tuner via navcoder to PAL. I opted for a camera in number plate surround to give a better view.
http://bit.ly/1d9oHO1
4 / 5 pin relay to connect up to reversing lights and pin 17 on the blue plug to the tv tuner, this will ground pin 17 thus will change sat nav display to reversing camera whilst in reverse.
Any 12V automotive relay should do the job, it does not have to carry much power.
You would connect:
'85' to the reversing light power cable.
'86' to ground to complete the switching circuit.
'30' would be connected to ground.
'87' or '87a' would be connected to the pin 17 on the TV module, whichever is switched to connect to pin 30 when power is applied, I think it's 87, but check.
Hopefully get it all fitted this weekend.
I have a hybrid tv tuner now so have a spare old analog unit if someone what's to make me an offer on it.
Grr i quite fancy this... And i have an old analogue tuner too.
Look forward to seeing how it turns out.
Sent from my iPhone 5s using Tapatalk
Installed av cable
Open blue plug to tv tuner
Install ground cable to pin 17
Remove number plate and holder
Install new number plate surround with camera, drill hole through bumper for cables.
Remove rear bumper
Use grommet on right behind bumper , cut and feed cables through.
Refit bumper
Fit relay with wiring as above in thread.
Fine tuning tomorrow with finished pics
Sent from my iPhone 5 using Tapatalk pro
Half a day really to do the works, rear bumper is easy to remove, remove press in clips 3 per rear inner arch, undo bolts to underside of bumper then pull bumper off from each side slowly.
