I'm absolutely exhausted from spending the last four days on the absolute battle of:
- Removing very seized bush hardware
- Removing the bushes themselves (except for the outer shells)
- Removing the very seized outer shells
So apologies for the brevity, but I hope I'm getting close to having finally finished this absolute arse of a job!
Only problem is, I can't really work out the method for installing the new bushes?
I've borrowed a tool (a rudimentary one consisting of threaded rod, washers, nuts and a press cup/receiving cup) but there's simply not the clearance against the brake disc shield to get the press cup into a straight-on position, let alone the receiving cup.
Is there a trick to getting the necessary clearance? Here's a picture I took when the bushes were still in (so my rod was in there factory-straight), demonstrating why I couldn't use the tool to remove them.
