Replacing Bwttery - Reset required?
robbee
Hi all,
If I remove the battery to charge it (dont have a garage) will I have any problems when reconnecting it? Is some kind of a dealer reset required, Is there any procedure I should follow?
Thanks for any advice,
robbee
You'll know it's in Transport Mode as more than likely the heater/AC won't work properly and will only give a very minor blow, I know this as mine is currently in transport mode, to get get out of TM will have to have a reset done from a garage to 'delete' TM, again I know this as BMW did this on mine and fixed the problem but because I'm having battery failure problems it went back into TM.
It won't go into transport mode if battery is not connected. It's when it us send draining down that causes the problem. My old z4 drained twice though but never went into transport mode, so I guess its pot luck on that front.
robbee said:
Hi all,
robbee
If it's only as a maintenance charge, have you thought about a PV (solar) battery charger ?
Whats this very minor blow you speak of..? :P
