jamiez said:
Hi - i have the pleasure of a large crack in my original ///M windscreen and I really need to get it replaced and wanted to get your feedback from past experiences. I have searched the forum - but not found anything specfic to my questions:
1) Am i safe to go via insurance and say Autoglass or the like?
2) Will i get an OEM screen? If not what should I be asking for?
3) Any specfic tips i need to say/ask for when ordering the replacement?
4) any tips to avoud any horror stories?
Thanks all!
Jamie
Hello,
I had mine done a few months ago.
I specified an original BMW screen. After a load of arguing, they agreed. If you do not specify, they will fit a cheap copy screen. In my experience these can vary hugely, some being absolute toilet and others being OK. OE is best though IMO.
I forgot to specify original BMW seals though! When the fitter arrived, the non OE seals were simply awful and did not fit the screen properly when the fitter was checking it all out on his bench. Luckily enough, they agreed to go and get an OE seal.
There are a few plastic clips around the scuttle and bulkhead panels which need to be removed and will probably break. I went and bought a few new ones and fitted them after. It was not the fitters fault, they are poor, cheap USA plastic and very brittle.
Watch, help and look after the fitter (cups of tea, biscuits, etc) as I did and you will get a better result.
It was not easy to be honest, the trickiest bit was locating the screen into the arpeture because there is a fair amount it could go left, right and up and down. I helped the engineer doing the passenger side and he did the drivers side. Me helping avoided him having to set up some contraption on the window which did not look like it would be good for the regulator If it is not located perfectly, you will end up with gaps between seal and body.
