Replacement exhaust tips.
D6GMB said:
Bing said:
1200mm might look a bit ricey :?
:lol:
Yes just what i was thinking :thumbsdown: .
They are 20mm too long as well which means they will stick out past the bumper quite a bit.
Have just removed my tips (easier than i thought) and have ordered a polishing kit of fleabay,it consists of three different grade polishes and three polishing mops and an arbor attachment for any drilling machines all for the princely sum of £13.
Will post up the results in a few days,but dont think i will be going for the new tips.
20 mm too long - so you cut them back :P
AlanJ said:
D6GMB said:
:lol:
I had thought about cutting them to be honest but glad i didnt buy them as i dont think you would be able to cut them then fit them properly.When i was looking at mine today they appear to be double walled and the only single piece of metal is where the holes are for fixing,so by cutting 20mm off would possibly be too close to the double walled part of the tip.
Does that make sense,kind of pricey to start loping bits off and knackering them :cry: :cry: :oops: :headbang: .
So, like so many M's my exhaust tips look a bit ratty. I really like the look of those 'euro style' tips mentioned earlier in the thread and, not being adverse to a bit of modification, I thought I'd see how I could make them fit.
Having a good measure up with the Verniers it appears to me that the 61.5mm diameter is just about right for ease of fitting (I make the standard M 60mm) the next issue to overcome is the length. At 120mm long, the 'Euro style' are indeed 20mm longer than the standard M meaning that, if the existing rivet holes are used they would stick out beyond the bumper wayyy too far. But don't let that put you off.
Having a crawl around under the car, there is almost exactly 20mm behind the standard tip to play with (up to the front edge of the cut out in this photo - please excuse the filth) therefore, if the 'euro tips' were pushed back as far as they can go and new holes drilled, it seems to me that they would be bob on!
Does anyone have any conflicting views before I stump up a wedge of green?
DD
edit: oops, only read pg one :D
I bet MM can make something nicer for a better price, and keep the money in the forum :)
jimmybell said:
I bet MM can make something better.
Cool, I'll happily wait until MM is back on his feet (no pun) to see if he can meet the challenge. :thumbsup:
The previous twonk owner of mine was clearly naff at parking as one of my tips is wrinkled like its reversed into something flush on.
Ha ha might be a while before I am back next week I would think.
Can't see it being a problem at all. If you like the look of these. It's a long thread not sure if you have seen it?
http://www.z4-forum.com/forum/viewtopic.php?f=2&t=49941&hilit=Machine+monkey#p724676
Indeed I have, I really like the turning marks, although not a fan of the 'bolt on' but they can be left off in favour of a rivet set up I suppose.
Could you achieve the step from 60 to 70 something mm?
I don't have access to this link. What do I need to do?
May be a project for me someday if I can find some inexpensive tips and if I still have my OE exhausts :wink:
Sorry Hadies The links have been closed down as i am unable to make anything at the moment. I am setting up my workshop at the moment so January February i will be up and running and able to help out anyone that needs some tips custom making :thumbsup:
Me neither :(
