estoril said:
Shipkiller,
Interesting observations.
I do have track, spring and trackday experience just not in this car and many years ago....about 20 and in a Westfield!
I am planning on doing a few track days in my car this year and was planning on running the OEM pads for the first one and then replacing them after the first event with either OEM standard pads or an upgrade in prep for forthcoming track days.
I have had great experience with EBC yellow stuff pads in an Elise but I know that a particular pad type does NOT always have the same results in different cars.
Thanks for all the feedback.
Darren.
Since you have not done a HPDE in a long time, but are planning on getting back into it, that changes things a little.
It had been two years since I have had some track time when I went two weeks ago. It does come back quickly, but I could not out drive the car... so using your OEM pads until they wear out is a good idea and the OEM pads will wear quickly as BMWZ4MC stated.
The OEM pads are real rotor friendly so you will not have to worry about destroying your rotors earlier than necessary. Dedicated track pads will wear a rotor out rather quickly. ///M rotors are expensive....
One of the worst things a new driver (to the track) can do it take a car to the track, that is so capable, he really does not learn as fast as he could with a lesser car... It is harder to learn where the edge is with a more capable car than with a less capable car. I learned more with a Mazda Miata than with my buddies Cayman...
The only thing I have done to my M is pull the camber pins and replaced the brake pads with CoolCarbons.
I replaced the OEM pads for three reasons.
1. Less brake dust.
2. Higher temp range.
3. Rotor friendly.
I specifically will track my car (job requirements permitting) at least five or six times this year (may be more) and did not want to have to replace my OEM pads every other event. The events I run are two day events....so that's a lot of days on the track.. At Virginia International Raceway (VIR) two weeks ago, we were driving the North Course which is a 2.25 mile course. In two days I put 272 track miles on the car....
After several events and my skill and comfort level has progress to a certain point, then and only then will I start to think about additional modifications to the car.
This is a truism, Fix the driver before you fix the car.....
You will have a great time when you go and shake out the old cobwebs..
