2004, E85, M54 3.0i, 59K, manual.
So I bit the bullet and bought all 6 new fuel injectors. The suspicion from several sources (including member GnomeDoctor...Thanks!) was a leaking injector. So instead of trying to figure out which one was the issue I bought and installed all 6 this morning. Not a bad job, getting the electrical connections off of the old injectors was the most difficult part (broke a small piece of the plastic off one side of the #6 cylinder connector).
When I buttoned everything back up and started the car it had a pretty bad miss. Pushed down on each connection to each injector, all seemed to be tight, I was worried that the small piece I broke had something to do with the issue. Anyway started it 2 more times, same problem...a miss. I have new coils waiting for the time they might need installed but I did not want to put them in now. My old Ducati mechanic told me years ago that when there is a problem always check the last thing you worked on. So I did not want to add the coils to the mix but I did unplug each and re-plugged them.
So I ran a diagnostic with my Foxwell hoping that it would show me what cylinder was having the miss...it did not. Removed the Foxwell and started it up and no miss. Took it for a short ride (in-case it had problems) and it ran fine.
All that to say...any ideas why it was missing at first? Could it have just been something in one of the injectors from the manufacturing process?
I must admit that I am not totally confident that the miss will not redevelop but what can I do but keep my phone and insurance card with me when I am driving.
Any thoughts on what might have happened would be appreciated.
