No, not the usual Can I do it, but a bit of a shocker this afternoon...
I purchased a spare set of 108's and took then to my local tyre shop this afternoon to strip off the old tyres that they came with. OK so 2 had plenty of tread and could be fitted back later, but I'm planning on fitting 452's on, them so wanted them ditching.
Interesting point was that the fitter pulled off one and commented it had been repaired and you could see the patch on the tread. The inside of the tyre was full of large balls of rubber (I mean handsfull of the stuff) and he pointed out what had happened. The tyre had been punctured and then driven as a run flat. This had (over presumably just a few miles) caused a total breakdown of the inner tyre wall at the corner between wall and tread. I was amazed at it. Even after the repair it had continued to inmternally disintegrate into a ragged mess, while on the outside it looked perfect. Shame I could not get pictures as they were closing shop.
From now on if a run flat were to puncture and I had to drive it at all I'd dump it immediately. Don't fancy 150+ mph potential with that going on inside a tyre.
