Removing front strut
ZetaTre
 San Diego County
Today, althoguh I was totally missing the motivation (and I must admit that's part of the problem), I decided to remove the front passenger side strutt to replace the upper mount which cracked.
I got stuck so I went back and checked the TIS and is says I need to remove the two bolt joints (control arm and steering tie rod) to basically remove the wheel hub.
Is there a way around it? Would the traditional ball joints fork or is required some fancy tool?
PS: I think the ///M has the old design...
Finally got back to this yesterday and managed to replace the strut mount.
I end up removing the steering knuckle from the control arm as recommended by the TIS: it's not that hard at all as long as you have the proper tool. You need a ball joint separator like this one:
The two ball joint (tie rod & control arm) broke loose with no problem.
Disassembling the strut it's a bit tricky too: the srpings only have 2 coils exposed and the traditional spring compressor like this one
couldn't compress it enough. I had to buy a different one
And clamp it on the upper and lower plates: although this is not the proper way to do it worked just fine (just be careful)
