Removing Chrome door grab handles???
ap123ap
I cant for the life of me get them off!
Followed the info below with no luck... I dont want to break the clips so I dont want to force them too hard...
cj10jeeper said:
To remove them you slide them upwards a few mm then very slightly lift the lower edge away from the black handle and then slide the trim down and off.
If you are not careful you break off the lower locking tab and hence why so many end up being glued on at the bottom :thumbsdown:
If you look right underneath the handle at the bottom there is a small hole. Put a small screwdriver in there and push very gently while pushing the whole handle upwards. Should pop out.
