Removing Air Vents... is it possible
oo7ml
Hi, i'm hoping to try fit my AUX lead AGAIN tonite... i tried to feed the lead up through the panel under the air conditioning controls at the weekend, however i nearly broke my wrist :o
On my previous Z4, i removed the air vents and then removed the radio... however i found it very hard to pull the vents out once i had the clips down (highlighted in red below) without marking the surrounding dash
The tutorial below suggests placing a screwdriver between the vents and the surrounding dash (highlighted in blue above)... however i found this marking my dash the last time, no matter how careful i was...
http://www.z4-forum.com/forum/viewtopic.php?f=31&t=15087
Can anyone suggest a more suitable way of pulling the vents out without breaking or marking anything... thanks in advance...
Yes, strong enough to get it those 3 mm forward after which you use your fingers to lever the rest out.
Don't use a screwdriver for the sides, ever ...
(my old RAC card was stronger, which is what I used).
Ok cool, will try it later... would love to see what they use in the BMW workshop for this kind of work...
A device looking like a credit card actually. I have the retrofit instructions for the satnav and that is exactly what it is.
You could always start with one credit card and then when it has moved out a little bit slide another credit card in behind the existing one to give it more strength.
First time I took mine out I used a row of lolly sticks across the top and it popped out before any of the sticks broke.
Good luck :thumbsup:
hahah, yes, that would always work.
Speaking of the devil - what happened to him?
there's a certain technigue to it, last time i removed mine i managed to pul it out with just fingers
srhutch said:
Can't have been in place properly to begin with then.
i had to release the clips with a screwdriver, then i managed to pull the vents out my fingers, i think
Been in and out several times with just fingers, all fits flush. Your not in a hairdressers rag top are you, heard those drivers often bend a nail or are a little limp wristed ;)!!
:lol: :lol:
credit card is the best!! I use it to open all panels in the car now...
as for the fingers - wouldn't you need long girlie fingernails for that??
dead easy use narrow teaspoon handles vents pop out,all I need is the connector cable and facia plate now,oh and replace the aerial and run the cables to the dash.
