Removal of the catalytic convertor...
mystik
 i'm from the bay (california)
Went and got my California smog check for my upcoming yearly car registration and after it was all over and done with, I wanted the cat gone. Why? I wanted a louder exhaust system, basically. As for performance, a lot of people were saying that the sensors will get all messed up and that it'll pretty much ruin the car if I drove without a convertor. I'm not too concerned about going faster and I'm sure removing the cat will not hinder my performance. But... What do ya'll think?
Leave the catalytic convertor or have a straight pipe setup? What are your views and opinions on removing the convertor?
Just leave it on, over this side of the pond, de-catting a car is a mod done by idiots in over tuned cars. The 3.0i engine sounds good enough without making it sound like a rally car, which would wreck the whole image of the car.
If you want a louder exhaust note go for a new back box, there are some good ones on the market which will give a louder, deeper sound without sounding too chav.
Removing your CAT will not hurt the engine.
BUT
You will get a SES light, since the DME will see no difference in O2 sensor inputs between the front (pre-cat) sensors and the rear (post-cat) sensors.
The only way to remove this 'reliably' is with a DME software change. I have seen some other ways of overcoming this over on the E46 forum, mainly used for installing headers which have no cats, some work, some are hit or miss, but a software change is the preferred method... and expensive.
If you really want to remove the cat and go through all that trouble, you ought to get a set of headers. You will be louder, have more power and better fuel economy.
How do you 'over tune' a car? :headbang:
ksher said:
In UK, removal of catalytic convertor will fail the emission test.
Unlikely on a modern car with multiple catylitic convertors, my last car would pass with only the pre cat installed and the main cat removed. Even with no cats installed it was a borderline fail and that was on a 16v turbo engine from japan deigned in 1994 so hardly cutting edge.
The problem with the Z4 is I believe the o2 sensors are connected into the cat's upstream and downstream so your bypass pipe would need to accomodate them.
