Removal of lower windscreen scuttle link?
Don't bother using anything on it. I did that to mine and it's faded agan within months.
Easy enough job to take off. Remove caps from wiper arms to expose the nut, then undo, carefully remove wiper arms (so as not to let them spring back onto the windscreen), then remove a bit of foam like rubber trim and it should just unclip off.
10 minute job. Easily 5 minutes if you work quickly.
http://www.bimmerforums.com/forum/showthread.php?1115530-Fix-walkthrough-for-faulty-wipers&s=a442e6588e34a249a0defb924e706fc3
You need a puller for the wipers & the plastic fixings under the bonnet are a bit fiddly, sure you will be fine!
Here you go mate :thumbsup:
Regards
Mega Expensive JE i would check out the price before you decide, the amount it costs will be a couple hours labour for an engine swap!
I don't care anymore, but that's because I just want to drive it and enjoy the power. You can't do that though I guess :P :evil: :poke: :driving:
