2003, 2.5 - US version- where can i find the relay's for my car. Also need the map of the relay box. Here my problem.
Bulb indicator is on:
1.Driver side rear light - turn left both turn(orange) and tail light (red) blink.
2.Driver side front light - Head lights work okay. Front turn light (orange) 2 of 2 work when turning/blinking. But if you are not using turn signal. It looks like 1 of 2 bulbs is out.
remedies tried:
1. replace all bulbs, replace all sockets.clean both rear light assembly. clean all contact points.
2. Check all wiring harness both left and right - no fired harness.
3. Check 3rd brake light wiring for possible ground - okay.
4. reset the car by pulling negative off battery for 1 hr.
5. check all fuses.
need help.
remedies tried:
5. check all fuses.
need help.
