*REDUCED* Z4M Brake Upgrade Kit - Porsche Brembo Front and Rear Calipers
gregl342
 Oxford
Hi all, I've been having a route around the garage and forgot I had these. I no longer have my Z4M so selling them on.
Front and rear Porsche 911 4 pot Brembo calipers to fit the Z4M.
Front Calipers:
I had these fitted to my car before I sold it, great setup, really improved the pedal feel. 4 piston Brembo front calipers from a 996 911. I had these calipers machined down 5.5mm by a machine shop so that the pad has full sweep accross the 345mm Z4M/CSL front discs.
The calipers were fully rebuilt and painted back in October 2019 with new pistons and seals. However the paint is showing some bubbling, I think as a result of sitting in box in the corner of the garage for about a year :headbang:
The brackets are from Creation Motorsport, these ones:
https://creationsmotorsport.com/brake-upgrade-porsche-calipers-brembo-bmw-m3-e36-e46-1608.html
All caliper hardware is included. Also included is a brake pad wear sensor that fits Porsche brake pads onto the BMW connector.
HEL braided brake line that adapts the Porsche caliper to BMW brake line.
Rear Calipers:
I never got around to actually fitting these! These are 4 piston Brembo rear calipers from a 996 911. The shade of the paint is a little different, noticable when side by side but probably not if they were on the car. These were rebuilt and painted with new pistons and seals in June 2022. Not been fitted since. Just been sat in storage in the garage so a few minor defects present in the finish.
Again, Creation Motorsport brackets, brand new, these ones:
https://creationsmotorsport.com/brake-upgrade-porsche-calipers-brembo-bmw-m3-e36-e46-1609.html
Custom HEL brake lines I had made up to be the right length for the rear of the Z4M which is a little different to the E46 M3 hoses, brand new.
Brand new EBC Bluestuff NDX brake pads. These are Porsche Boxster (986 non-s) front pads that, when used with this caliper on the rear M3/Z4M discs, gives full sweep of the disc.
All in all, this setup should be a bolt-on affair with the Z4M. To complete the kit you would need the following two things:
Front brake pads. To match the Bluestuff it would be these ones:
https://www.design911.com/p/ebc-blue-brake-pads-ndx-race-porsche--996---997_2_2_2/
Rear brake pad wear sensor. I'm not sure where to source this, they should be the same as the front but might need to be a differnt length. The front sensor was sourced here:
https://www.ebay.co.uk/itm/111259286364?itmmeta=01HZD868JPG7Q9P90MTDK30YA0&hash=item19e791fb5c:g:AScAAOxyVaBS2bRm
Can probably be cut and extended to suit if needed.
My asking price for the whole lot is £600.
Happy for buyer to collect from Oxford OX4 or also happy to send via courier at buyers expense, £30 p&p to UK mainland.
Payment via bank transfer only please.
Great purchase, I was hoping to snap these up tonight but hesitated for too long.
My bank balance is grateful that Rags beat me to it!
