BPM-Z4R said:Swiftly said:BPM-Z4R said:what glue did you use to secure the handbrake gaitor? my black with red stitching has turned up. gear one was easy as you say. just the handbreak one to do now.![]()
I used a tube of Evo-Stik instant contact adhesive, it was just what the job needed.![]()
Thanks, is that something hobby craft will stock?
iPhone 5 TapaTalking
jaRED said:That's looking very nice. Now wondering if I should be adding the red gear gaiter to coordinate with my red/black dash trim.....
Leesfarm07 said:Patience is the key with the handbrake gaiter. Don't rush the glueing, smear a bit on both surfaces and allow to dry before contact! I found it best to stick the inner bits first.. that gets everything lined up. Good thing is if you make a mistake its not the end of the world to pull it apart and re-position
