stevedavo86
Folks - red exclamation mark light in brackets has just popped up....did a quick google and looks like could be to do with tyre pressure. Can anyone confirm this is the case please?
greg81 said:
greg81 said:
stevedavo86 said:greg81 said:
Yep thats the exact one. Will check pressures today at the garage. Does anyone know recommend tyre pressures front and back for a 2.0i E85?
Ducklakeview said:Yup, it's the TPMS (tyre pressure monitoring system) Either; you have lost pressure in a tyre, OR if you have recently inflated tyres/had new one's, it needs recalibrating as follows;
Start engine, and whilst stationary, press and hold the TPMS button just in front of the ashtray, until the symbol illuminates on the dash, symbol is amber from memory when calibrating. Then simply drive in a straight line, and it will recalibrate in a few seconds.
Mike
Ducklakeview said:greg81 said:
That's not an E85 dash, different symbols/procedure for the E89 as per my post above.
Mike
stevedavo86 said:Folks - red exclamation mark light in brackets has just popped up....did a quick google and looks like could be to do with tyre pressure. Can anyone confirm this is the case please?
C58 said:it will turn the red light to amber, drive for a minute and it will disappear
stevedavo86 said:Not put air in it yet but pressed the button until it went from red to amber then drove away and it seems to have disappeared?!
Ducklakeview said:stevedavo86 said:Not put air in it yet but pressed the button until it went from red to amber then drove away and it seems to have disappeared?!
IT will do, as it's now recalibrated to the air that is in (or not) the tyres. First thing you need to do is check the pressures!
Mike
