Dav the wheel nut said:
ben g said:Would be fine with a skinnier tyre on them.
Mine are 10j et38 and tuck under the arch of my lowered z4 fine. Although the rear camber does change a bit when lowered.
dans6490 said:ben g said:Would be fine with a skinnier tyre on them.
So a 9.5j with 35 offset would fit perfect presumably? Found these-seems a reasonable price???
http://pages.ebay.com/link/?nav=item.view&alt=web&id=271657613116
Dav the wheel nut said:dans6490 said:ben g said:Would be fine with a skinnier tyre on them.
They seem to be 9.5s on the fronts as well?
If they are I doubt they will fit.
Couldn't see where it says offsets are 35.
Dav the wheel nut said:In that case they will fit as long as the centre bore is 72.6
I have the same on mine and lowered with no issues.![]()
