rear sway bar end links?
mister_roger
 Bellevue, WA
Does anybody know if aftermarket rear sway bar end links are available for our cars? Apparently my driver rear end link has snapped (again), and I'm looking for a stronger set so I that I don't have to replace them as often. They are quite a pain to replace.
I saw that Turner Motorsports sells E46 rear end links, but not sure if they'll fit a Z4. From the picture on their site, they appear to be much shorter than the Z4 links. Does anybody have any insight or experience with this?
P.S. I have eibach springs and Hotchkis (H-Sport) sway bars installed, so I'm sure the added stress and tension is whats causing these to prematurely break.
Is it a stock part you're talking about? I did a quick check on realoem, and the '03 Z4 2.5i shares the same rear end links with the E46 M3 and the Z4M's. If it's some aftermarket end links that Turner is selling, I think your best bet is to give Turner a call.
Don't hesitate to let me know if you need an extra pair of hands to help you with the install. :thumbsup:
Hey you're right, they are the same part number. I thought i remember seeing them as different part numbers when I had to replace them a while ago. Hmmm. Well I think there is a good possibility that the TMS end links may be able to fit on a Z4, but i'll give them a call tomorrow just to verify. The only thing I'm concerned about is the length.
Thanks in advance Eric. I'll let ya know how this ordeal goes. :D
I got a set of rose jointed rear links from TMS. You have to specify whether the car has been lowered or not and I'm sure they were in the E46 section. They work great though and are adjustable for length. They also have a grease nipple on the upper pivot. I'm sure they were about $60 for the pair.
I put front and rear aftermarket sway bars on my skyline, pretty much eliminated any body roll. I think I will be looking into a set of these in the new year!
Anyone in Australia got a set or seen any for sale?
