Rear Suspension Help!
Z4JB
Derbyshire, UK
I have recently bought a 2004 3.0i - currently sitting on 108’s and Goodyear Eagle F1’s with 74k on the clock.
The car doesn’t sit unevenly however I have noticed the shocks at the rear sitting differently. Could one be collapsed?
Are sure a spring hasn't snapped ? (It's the spring rather than the shock absorber that determines the ride height)
It's in for a water pump replacement tomorrow so I will get them to check the springs, I wouldn't be surprised if that's what it was. Are they mega money to replace? Might as well get both sides done whilst I am at it. :headbang:
Thanks all for the info, it's almost like the car knows I am happy to give it some TLC so it's throwing as many issues as it can my way all at once!! :headbang:
If you have a jack and are capable of taking a wheel off, then inspecting and changing the rear springs is one of the easiest DIY jobs to do on a Z4. No tools required.
Hi there Z4JB. There's a lot of corrosion on those top caps and the top of the piston in the first photo. The dust cover is split in the lower photo. I would hazard a guess from this that these are the original '04 Sachs dampers and almost certainly they (and the fronts also ! :cry: ) will be shall we say WELL past their best with little or NO damping at all :( Bin 'em and fit new. It will transform the ride and handling :thumbsup:
Yeah I’ve definitely decided to switch them all out. I’m pretty confident the N/S/R spring has snapped upon inspection. Hoping it’s not going to burn a hole in the wallet too much!! :driving:
where you based bud- I've got a couple of used springs- think they are slightly lowered (they aren't standard) with surface rust that you can have
Thanks bigwinn, I really appreciate the offer! I’m in derbyshire, but I think I’m going to want to keep the standard ride height though, I already have trouble clearing some speed bumps as it is! Am I right in thinking the 3.0i was slightly lower as standard or have I got that wrong?
Yes, all 3.0 cars were fitted with M sport suspension as standard, unless specified without. (prefacelift only) the facelift cars had a dedicated Sport and SE where the SE had the higher springs fitted.
Agree with all the above but I will point out that the only issue you can see is the bump stop has slipped down the shock a bit, so nothing is about to break.
Thanks all, I’m definitely going to get them refreshed. Can’t wait to see how it feels after they’ve been replaced!
