Rear right brake/reverse lights
Hi folks, me again...happy to report my roof errors haven’t returned, but I’ve now had 3 different rear right bulb errors. The bulbs are fine and work on the left, and swapping around, maybe even just re-seating seems to fix the problem.
Is there something that could impact various bulbs? A relay? I’m pants with electrics so any help would be really appreciated!
Check the connections for any corrosion, spray some wd40 etc inside the connectors before replacing the bulbs & try again.
gameover000 said:
Thanks Rob - is WD40 safe for everything around the connectors/wiring then, or do I need to be careful?
It’s safe for everything (apart from brakes) :P
gameover000 said:
Thanks guys!
Where do I check the earth?
Remove the interior boot trim panels and look for wires that are bolted to the framework.
Stuart
