Rear Ride Height?
JayT
 London
Hi, does anyone know what the standard rear ride height is for a pre-facelift on 17" wheels??
Cheers!
well .... 1/2" less if changed from 18" or 1" less if changed from 19" :rofl:
sorry don't know what you mean, perhaps explain it a bit more :poke:
JayT
You need to specify the year and model. Especially if it's on sport or standard suspension, pre or post facelift. If you let me know the 7 digit vehicle code I can look it up on the TIS. The Code is something like 'LT00123'
Standard ride height is then measured from the top of the wheel arch vertically to the centre of the rim or lip (can't recall)
Rolf - tyre size does not affect ride height as the profile of tyres is changed to compensate.
It's all been posted before a couple of times, Sport vs Non Sport and all the different wheel sizes. I've been trying to find it but just don't seem able to find it. I know it's on the TIS disc but unfortunately I don't have mine with me to copy for you.
Sorry.. should have been more specific.
2004 (pre-facelift), 3.0i, Auto, Sport Suspension.
Think the vehicle code is LT02566.
Thanks!
Here you go. I remember posting this before, once I thought about it.
You should therefore be 590 fr and 576 rear
The suggested BMW factory measure point is as follows:
Attach measure to rim flange at bottom middle and measure to lower edge of wheel arch. By rim size you should get:
Series (Standard)
Front Rear (MM)
16" 589 576
17" 605 592
18" 617 604
19" 630 617
20" 643 630
Sport or ///M suspension
Front Rear
16" 574 560
17" 590 576
18" 602 588
19" 615 601
20" 628 614
All should be +/- 10mm
Sorry to drag up an oooold thread. But can someone give me some advice.
Recently bought a 2004 3.0 roadster and I'm convinced it has the wrong rear springs fitted. It has 18" wheels with the standard bridgestone RFT fitted.
Both were replaced by the previous owner, by BMW, during MOT's over the last 2 years.
I've always thought it sat high at the rear, so today I eventually got round to getting the tape measure out.
Measurements are as follows:
Front Nearside 600mm
Front Offside 599mm
Rear Nearside 610mm
Rear Offside 610mm
All measured using cj10jeepers method above.
This would indicate to me that the standard rear springs had been fitted instead of the sports springs. As even with the +/- 10mm allowance, it still sits 12mm higher than the numbers above!!
I'm tempted to fit a set of eibachs, give that the latest replacement was fitted by bmw in May last year, I think I'll struggle to get anything out of them.
Any thoughts?
Cheers in advance all!!
Anyone else have any thoughts? What do you think my chances are if I contact the dealership who fitted the wrong springs?
Only issue is that I travelled half way across the country to buy the car!!
EDIT: Scrub that, just discovered that actually they were changed in 2008 and 2009 respectively, so I may aswell give up on BMW admitting they fitted the wrong ones!!
Looks like Eibachs it is then! :evil:
Don't forget to factor in the extra cost of fitting the fronts. Big pita and probably need a garage to do, compared to the rears that are 30 minutes a side max. You'll also really need an alignment doing too.
