S spammy Member Dorset Oct 13, 2022 #1 hi, all just put new rear parking sensors on, so when i put it in reverse i don't get the one-off beep anymore but the sensors don't work ether? could it be the module? and where is it. if anyone knows would be great .
P patriot66 Lifer Southport, Merseyside Oct 13, 2022 #2 Is there any 'ticking' if you put a finger close to each sensor ? The module is behind the boot carpet by the boot light on drivers side
D dhobbs Senior member Oct 13, 2022 #4 I did mine recently and had to disconnect the cable to the module so I'm surprised you didn't have to. As mentioned module is in rear right corner of the boot behind the carpet
S spammy Member Dorset Oct 28, 2022 #6 thanks all, all done new sensors new module and all working fine.
K kavindajd Member Oct 28, 2022 #7 Got a similar issue on my E85. Parking sensors all work fine with the exception of the driver side corner... No ticking - I presume a dead sensor? Anything to check before ordering a new one?
