Rear Light Problem With my brand new 2005 Z4
Sleep-O
New member
Hi All,
Long time listener, first time caller. Great site by the way!
We have just become the proud owners of our first Z4!! :D
We have the common problem of having one tail light (Passenger side) being dimmer than the other.
Although this has been mentioned a couple of times on here, I can't find any part numbers or photo's of how to fix it.
I followed a fix from E46 fanatics which didn't work (link below)
http://forum.e46fanatics.com/showthread.php?t=472357
Is there anyone on here who has had/cured this problem?
Any help appreciated.
Steve :)
Welcome to the Forum - and before anyone else comments put an entry in the Newbie section with some phots of your Zed.
As for your problem several things can cause this:
*A failing filament in the lamp on the less bright side
*Different manufacturers lamps in either side (yes they vary in intensity from different manufacturers) - just change them over and see if the same thing happens
*A bad earth connection to the 'dim' lamp (check all connections and clean where neccessary - quick spray of WD40 in the connector or similar can often resolve the problem) - if you have a 'meter' you can check the voltage across the terminals to see exactly where the problem is.
Go for the easy fix first - changing lamps over etc then a clean of connections if the change makes no difference.
Hope this helps.
I'm someone who'd previously posted about one lamp being dimmer than the other, but mine was due to a crap connection using scotch-locs when doing the full-circle brake light mod (search will bring it up). When I reverted my wires back to standard and changed the bulbs it was fine. Basically, first step would be to replace BOTH rear bulbs.
HTH.
Ally
P.S. Welcome to the forum :)
HI 8)
I've also suffered the same problem, I changed the bulbs for both of the rear lights and still the problem existed.
Then the full cluster on the o/s packed up and apparently my earth bar as cracked.
It's repairable but I've picked up two 2nd hand rear cluster for £50 on Ebay :)
Hope this helps.
