gazrobbo said:
I have exactly the same thing on mine. noticeable when moving slowly in traffic, pushing the clutch in when in first gear. also when reversing up my drive on a slight hill, when letting the clutch out.
I had the flange grease thing done, but it didnt fix it, dont want to spend a fortune getting mechanics to keep looking at it so once the weather gets better Im going to get it jacked up and see if I can see anything myself.
If you do get to the bottom of it please let me know what it was!
As I said in an earlier post a while back, most of my clunking was coming from the drive shaft where the two sections are splined together. My Indie dismantled the drive shaft and reassembled it with a ton of silicon in the grooves of the splines...he said he had performed this many times before and it should be a permanent solution. It was just some wear on the splines.
With the car on the rack, you can leave it in gear and turn the rear wheels back and forth. It will be very easy to determine where the noise is coming from. I was under the car when we did this and I was totally surprised to hear it coming from the drive shaft joint when I expected the clunk clunk to be at the diff flange. Sitting in the car it sounded like the noise was coming from the differential area.
Just lift the car and check it out...you will have to drop the exhaust and the covers to pull the drive shaft for a fix.
