Are you using the rose jointed ones? I thought about them as they get rave reviews, just thought I'd try something else. The anodised black appealed also.JimmiVW said:I'm running Turner Motosport rear arms, they came from the states, I can't remember exactly how much but price sounds similar from memory...
... http://www.turnermotorsport.com/p-3552-rear-adjustable-camber-arms-e36-e46-e85-turner-motorsport-streettrack.aspx
Stevie.w said:Are you using the rose jointed ones? I thought about them as they get rave reviews, just thought I'd try something else. The anodised black appealed also.JimmiVW said:I'm running Turner Motosport rear arms, they came from the states, I can't remember exactly how much but price sounds similar from memory...
What you normally find when you lower the car the standard adjustment isn't sufficient to correct excessive camber. These allow you to adjust it to whatever you require. You can also use them to push the hub out to fill out the arch and then use a Whiteline camber adjustment bush in the top of the hub to fine tune your camber.exdos said:The OEM system uses a simple eccentric bolt for camber adjustment and I've found it very simple to adjust. So what's the advantage of these arms for anything other than a race car, which might require more camber?
Stevie.w said:You can also use them to push the hub out to fill out the arch and then use a Whiteline camber adjustment bush in the top of the hub to fine tune your camber.
JimmiVW said:There was also some speculation of the US forums about the standard arms bending, but I really think this was only down to 'mis-use' rather than defects, certainly not enough reason to swap in my mind.
They are rubber bushings fitted, but I've poly bushes both top/bottom inner bushes. With the expected power, I need to control the suspension fairly tightly. I've sized the adjustment available on these arms and they can run 10mm shorter than standard and 30mm larger. So there's plenty scope for setting up., what I'm well impressed with is the threaded bar and threads in billet ends. They are very well machined with no play at all.GuidoK said:Stevie.w said:You can also use them to push the hub out to fill out the arch and then use a Whiteline camber adjustment bush in the top of the hub to fine tune your camber.
That's possible but you'll only gain about 4mm (that's about the extra width you get with max adjustment with a camber adjustment bush).
If you want to fill out the arch, a spacer or wheels with different ET would be more effective/easier I think.
At the rear you hardly have to worry about scrub radius etc.
Is that a rubber bushing that is press fitted in the inner joint and is it the same size as the stock one? (so that you can replace it with PU)
