Rear bumper removal
abeardo83
Does anyone know how to do it? Or have the workshop manual that shows it in pictures?
I want to fit my new rear vents, so could do with taking it off, to make it easier.
Managed to remove the rear bumper. Wasn't too hard really. Will try and post up what pics I took, and the process I followed when I'm home later on.
abeardo83's guide would be best but in the meantime - presumably it's a case of removing all the fastenings around the bottom edge (8-10mm nuts I'd have thought), in the wheel arch and a few along the top which might be hidden under trim. The side may 'pop' into some brackets so you might need to pull on the edges. Would have thought it will then slide off nice and easy.
