Rear break lights
Steve84N said:
OK, so I've found the various codes including:
BFD_SW1_STUFE3 - BFD stage 3
BLST1_BLST3 - BFD stage 3 flashing mode (Inner or Inner & Outer)
PIN5_10_BFD - BFD with brake lights
Mine is currently set to BFD 2 with just inner. It's set to use deceleration sensor 1 as opposed to 2, do you know the difference?
What's BFD 3 as opposed to 2 and what's BFD with brake lights?
TIA
Steve
I've not been able to find any info on the sensors or values so have left them alone.
I've not been able to toy with all the options but here's my current code, values dumped into excel and filtered on anything containing BFD:
PIN49_37_BFD nicht_aktiv BRAKE FORCE DISPLAY WITH INNER TAIL LIGHTS / LEFT REAR FOG LIGHT (DEPENDS ON CHASSIS)
PIN38_20_BFD nicht_aktiv BRAKE FORCE DISPLAY WITH OUTER TAIL LIGHTS (DEPENDS ON CHASSIS)
BFD_BLINK_EINZEIT wert_02 BRAKE FORCE DISPLAY FLASH OFF PERIOD
BFD_BLINK_AUSZEIT wert_02 BRAKE FORCE DISPLAY FLASH ON PERIOD
BFD_ABS_STUFE3 aktiv BRAKE FORCE DISPLAY STAGE 3 ACTIVATED BY ANTILOCK BRAKING SYSTEM (ABS)
BFD_STUFE3_TIMER wert_02 BRAKE FORCE DISPLAY STAGE 3 TIMER
BFD_SW2_STUFE3 nicht_aktiv BRAKE FORCE DISPLAY STAGE 3 ACTIVATED BY DECELERATION SENSOR 2
PIN5_10_BFD aktiv BRAKE FORCE DISPLAY WITH BRAKE LIGHTS
BFD_SW1_STUFE3 aktiv BRAKE FORCE DISPLAY STAGE 3 ACTIVATED BY DECELERATION SENSOR 1
BFD_SW2_STUFE2 nicht_aktiv BRAKE FORCE DISPLAY STAGE 2 ACTIVATED BY DECELERATION SENSOR 2
BFD_MINDEST_GESCHW wert_01 BRAKE FORCE DISPLAY MINIMUM SPEED
BFD_STUFE_2_VERZOEG wert_01 BRAKE FORCE DISPLAY STAGE 2 DELAY
BFD_STUFE_2_MAX_EIN wert_01 BRAKE FORCE DISPLAY STAGE 2 OFF?
BFD_SW1_STUFE2 nicht_aktiv BRAKE FORCE DISPLAY STAGE 2 ACTIVATED BY DECELERATION SENSOR 1
BFD_ABS_STUFE2 nicht_aktiv BRAKE FORCE DISPLAY STAGE 2 ACTIVATED BY ANTILOCK BRAKING SYSTEM (ABS)
BFD_STUFE2_TIMER wert_01 BRAKE FORCE DISPLAY STAGE 2 TIMER
PIN29_30_BFD nicht_aktiv BRAKE FORCE DISPLAY WITH INNER TAIL LIGHTS / REAR FOG LIGHTS (DEPENDS ON CHASSIS)
BFD3_ASC_TIMER wert_01
BEI_NSL_KEIN_BFD nicht_aktiv BRAKE FORCE DISPLAY NOT SIMULTANEOUSLY WITH REAR FOG LIGHTS
PIN38_BFD nicht_aktiv BRAKE FORCE DISPLAY WITH RIGHT OUTER TAIL LIGHT (DEPENDS ON CHASSIS)
PIN49_BFD nicht_aktiv BRAKE FORCE DISPLAY WITH LEFT INNER TAIL LIGHT / LEFT REAR FOG LIGHT (DEPENDS ON CHASSIS)
PIN49_PWM_BFD wert_02
Bmwjay said:
just trying to get flashing tail light from light breaking also a full circle break light rather then half
You'll need the values above, but also to change these to active:
BREMSLICHT_ALS_STANDLICHT nicht_aktiv
STANDLICHT_ALS_BREMSLICHT nicht_aktiv
Thanks for that.
To your knowledge is this the code for the flashing centre brake light?
It may trigger it even though Pin 16 is for the high level brake light. It's difficult to experiment with as it needs triggering and an external camera.
If your light is breaking, stop it before it is fully broken. (Can no one properly spell "brake" on this forum ?)
