Rear brake pad sensor
darich
South Lanarkshire
In the process of undoing the back box delete, I have spent a little time under the rear of the car.
I noticed a loose cable/sensor dangling, not connected to anything - it's the rear brake pad sensor.
I've had a look on line and from what I can gather the sensor just clicks into the gap in the pads.....is it as simple as pulling the wheel, and clipping the sensor into the gap?
It should be but, sure as eggs is eggs, you'll be missing the little metal spring clip that holds it in place.
I've ordered a replacement sensor from Autodoc so hopefully the new part has all the pieces I need.
