So just had an issue appear over the past 24 hours. If I pull of in 1st gear there is a high speed rattle that matches up with the revs. 2nd and third gear and above there isn’t any sign of it. Occasionally, you hear it on the higher gears but not much.
If you rev it in neutral parked up you can sustain the rattle at about 2000 rpm.
The car is driving fine, no warnings. Just topped up the oil two days ago. Slightly judders in third occasionally. However, mostly it’s fine
Will book it in but any advice will be appreciated
