Rattle from rear only at motorway speeds
mackie
Anyone else had this? My car is 3.0si Coupe. Basically a speeds around 70mph or over there is a rattle coming from the back of the car. I suspect it's due to airflow as it's not evident at all a slower speeds. I've had a quick feel around to see if there was a loose heat shield but it all seems OK, the arch liners a firmly fixed in place too. I'm going to get new pads and disks all round soon so I might ask the garage to have a poke around while they have it up on the lift. I did ponder if it could be the rear hatch that was moving slightly but it definitely sounds like it's coming from underneath.
ETA: I've had a more detailed look underneath and found that there's a screw/rivet/bolt missing from the plate (6) in the diagram below. I don't suppose anyone happens to know what part I need to fix it correctly do they? For now I'm going to just try and zip tie it I think.
It might be the standard 8mm bolt which is used to secure most parts
I would remove a 8mm bolt from one of the rear heat shields and see if it fits
The hole it would screw into is quite small and the flange is thin suggesting it's probably a self tapping screw of some kind. I've zip tied it for now and will get it sorted properly when I get my brakes done.
