I’m in the process of changing the front spring perch on one of my KWs. There is a lot of play between the top mount and the top of the piston rod:
[vimeo]311074038[/vimeo]
Link, in case the embedded vid doesn’t work: https://vimeo.com/311074038
I’ve ordered a strut nut socket and will wait until I have it before I try and disassemble the strut.
The piston rod doesn’t move relative to the spring seat and the nut isn’t loose. Am I right in thinking that this is play due to wear in the top mount bearing and not just under-tightening of the nut?
It would make sense as the struts were upgraded at about 45k but the original top mounts were reused, which means that they are nearly 70k old now.
TIA.
TIA.
