I think that's a subtle hint that you might have a bit too much in your bagRubyBlueZ4MC said:I had this ages ago and realised it was my heavy handbag on passenger seat doing it. So I strapped it in.
Fanatic said:mac27040 said:if you go down the route of the bypass module, you will need the car coded to switch of the seatbelt chime as the car thinks there is someone in the seat. can be sdone in SSSv32 software retro section.
When i did mine i needed no coding after...worked plug and play![]()
mac27040 said:Fanatic said:mac27040 said:if you go down the route of the bypass module, you will need the car coded to switch of the seatbelt chime as the car thinks there is someone in the seat. can be sdone in SSSv32 software retro section.
Trust me if you use a bypass module then you need to code the car to switch off seatbelt reminder because the bypass module tells the car that someone is sitting in the seat so the airbag system works correctly.
I have coded lots of z4's because of this and have done it myself
Sent from my iPhone 5 using Tapatalk pro
