RANDOM DOUBLE WARNING TONE + Other
peds8045
Hope someone can give a clue to these two.
At random times with my Zed, after unlocking the doors with the remote, i open the driver's door and the drivers window winds down by itself. I've tried to figure out a pattern to the event but it appears to be totally random....any ideas?
The other issue ..again after unlocking the car with remote, put the key in the ignition and i get a 'beeeep beeeep' tone! No warning lights, nothing obvious and no pattern, totally random....has anyone else experienced this?
All help appreciated.
It's a 55 plate 2.5 model.
Hi
Interesting; I can't help on the bleeping noise, but I'd imagine it's the battery in the key? I understand (other members correct me if I’m wrong) the Z4 has a rechargeable battery in the key fob, if this runs low due to minimal use or short journeys it'll not have time to re-charge??
On the window; I have the answer; I bet if you press the remote un-lock twice it goes down, but not if you press the key once!! It's a programming issue, I had my roof, alarm tone and other remote key options activated, after this my window did the same, they simply re-set that option to off!! Simplessss!!!
Best
Aero
