Rain water coming in from top of driver side glass
xxniko90xx
 Boston, MA
I noticed that rain water is coming in from the driver side door. It doesn't look like the glass is touching the rubber seal on the door. Does anybody know how to fix this?>
You can adjust the angle of the pane. unfortunately you need to take the door card off.
There's some white carriers you can adjust.
When you take the door card off there is a large Torx bolt in the bootom of the window holder, you loosen this off and this allows you to move the window about a bit but its all trial and error to get it right.
try resetting the window before you start ripping the door cards off,
If i remember correctly with the key in position 1 ie first turn drop the window and hold the button down for 10 seconds, then bring the window back up and hold again for 10 seconds, do both at the same time....
think that is the correct procedure no doubt if wrong someone will notice..
