Radiator fan replacement
darich
South Lanarkshire
Hey all
My radiator fan sounds like a plane taking off - sounds like the bearing is nearing the end so I've got a replacement but can't find any guides online about how to remove and re-fit.
Can't be a difficult job but there's almost always a couple of awkward or hidden bolts.
Does anyone have any links to any online guides?
thanks
j3nks79 said:
Once you remove the plastic top cover it’s all self explanatory. Really easy job you’ll work it out
Great....I just had a concern that there would be some sort of special technique or hidden connections and I'm not keen on starting if it might mean the car is in bits until I can get someone more knowledgeable to look at it.
V easy
Top cover off 2xt30 and 8-10 plastic grommet screws
Unclip the connector
Move the auc
Unclip the one push grommet on the right and unscrew the t27 on the left
Slides up and out
bigwinn said:
V easy
Move the auc
Slides up and out
Excellent...thanks!!
darich said:
bigwinn said:
V easy
Move the auc
Slides up and out
When you fit the replacement be careful not to snag the lower hose. Make sure the bottom of the fan shroud locates properly in the slots below it or it can move back and forth a bit.
Thanks..I'll watch out for that! :thumbsup:
Thanks guys ..Job done.
1 problematic nut but a neighbour appeared and had the perfect tool so we got it without too much trouble.
All back together and sounding so much better!!
