Hi All
Quick question that i wanted to run by you and see what others think...
car - bmw z4 2.2 2003
car runs fine, no engine light or rough running....
ran a scan with the OBD and a couple of fault codes popped up. So i cleared them and then drove a for a couple of weeks and then checked again and only 2 have returned:
So I already cleaned the MAF a couple of weeks ago after my first check, just to see if that was causing it, as I have a K&N filter. It wasn't dirty at all, but i still cleaned it just to make sure. So now it has returned should I just replace the MAF? - if so can anyone recommend a cheap supplier as they are stupid money with companies like eurocarparts (£400quid!!!!!!)
as for the second code, I am not really fussed about having an oil level sensor, but can this potentially cause a problem later with running of the car, etc? - or am i ok to just ignore this
cheers in advance
paul
- 2783 hot film air mass flow sensor
- 27C3 thermal oil level sensor
cheers in advance
paul
