I Successfully moved the roof motor to the boot without removing the roof, following some of the great guides on here.
Three of the hydraulic hoses are plenty long enough but the one that goes to the top of the Left hand actuator is barely long enough. This means that it is stretched causing a small bend radius where it’s fixed with a cable tie under the coupling. I could remove the cable tie to release another cm of hose but that would then put strain on the coupling itself. Not seen anything about this in any of the guides so interested in experience from others who have done this mod.
I only noticed this when I pushed my phone into the hole where the motor used to be to photograph what was down there. If I hadn’t done this I’d be in blissful ignorance of a potential new problem!
Is this something to worry about or normal?
