So, I'm getting ready to do the front brakes and surprise! I need to get the wheels up off the ground. And I thought Miatae were low to the ground... Anyway, a couple of cobbled together wooden 2X10 ramp things and I can get my genuine Harbor Freight "racing" low profile jack under the front end. I gather from that fount of wisdom, the internet, that the front jacking point is the roughly rectangular stamped place in the aluminum under tray just behind the plastic one, roughly lined up with the front axle. So, I stuck my jack there with a small wood block spacer and it did indeed lift, but the aluminum stamped place kind of squashed back almost flat. I clearly can't jack at the side lift points and put jack stands on them at the same time, so a couple of questions.
1. Is that really the jacking point? If so, why does it deform so readily? Or is that a BMW "Character" thing, not for us mortals to question?
2. What is behind that place? Is there actually something there? From above, it looks like there's a stout crossmember, but it might be made of paper maché for all I know.
3. If that's NOT the front jacking point, where is it?
A little help from wiser heads, please.
