If you're going to run with a space-saver, and are unfortunate enough to need to use it,
which axle are you going to put it on?
With FWD cars it seems fairly clear the advice is to put the space-saver on the rear axle.
If you have a front puncture, you swap a rear for the SS, then the punctured front for the good rear.
FWD are unlikely to have different rim/tyre sizes between front and rear, so it's easy to do.
now, assuming you're not going to go very far, and you'll be keeping it down at a sensible speed
With RWD I *think* I'd still want the SS on the rear if possible (if the rolling circumference is very close)
Is this the best place for a space-saver on a RWD?
If your rears are wider, how well will they fit in the front wheel arches?
