Puncture warning light question
christhomasleeds
 Leeds
Hello all,
Having replaced my run-flats with Falken FK452 last week and whilst enjoying a much transformed ride the puncture warning light has come on on the dashboard. I've checked all round and everything is as it should be i.e no punctures, does anyone know if this something that will happen often or have I got a fault?
Thanks for any advice...
Simply need to reset the tyre monitoring system - happened the same in my friends E46 m3 after new tyres were fitted - the system trips as the rolling radius of the new tyres is different than what it has learnt (using the abs wheel speed sensors).
To reset (best check the manual in case im wrong!) - start and car and press the tyre pressure button near the heated seats/roof controls. The amber indicator should appear on the display, it should relearn and clear down once you have driven a bit.
