Puddle of water under car?
  • Start date Start date
A
Anonymous
Guest
Hi all. I stopped at Macdonalds on the way home tonight to go for a pee and it seemed my car wanted to join me.
I came back to find a small puddle water underneath. Not a huge amount but enough for it to trickle about a metre and form a puddle the size of a granny's pancake.
It was clear and unscented so pretty certain it was just water. The drop came from somewhere under the seats.
Any ideas? Could this be due to having the blowers on for a while when the roof was down? I seem to recall having a car that did that after the aircon was on for a while. Any suggestions of what else to check?
Thanks all
It'll be nothing more than water dripping as a result of air con on.
You can get similar after rain or washing when water drips out of e undertray as you drive.
Head gasket !!! Eeeeek :P
No not really, probably your AC, as mentioned, or could be your washer bottle/headlamp washers leaking or even your coolant expansion tank. But more than likely your AC :thumbsup:
Thanks all. As I suspected although still slightly comcerned as it was about 150 ml of water.
The heater was on for about 30 mins. Temp outside was about 17, but a cold wind
