Prop bolts spat and prop doughnut knackered
HelenZ4
 Middle England - AVFC
Prop spat two bolts out a couple of weeks ago, Sounded awful with banging noise on transmission tunnel. Garage sorted and fitted new.
Noise returned at the weekend - banging on transmission tunnel area - but only in first under load. Appears prop doughnut and possibly bearing knackered probably as a result of bolts going AWOL.
Looks like a known issue - what causes the bolts to be spat out and I don't suppose BMW will assist on an 08 car / 40,000 miles??? Errrrr let me think!!
Do I need full prop with doughnut and bearing or just the doughnut and bearing? Ideas of part numbers and prices please?
Many thx
The doughnuts are a known point of failure. And I could imagine that if that went it could cause vibration to spit a bolt out? And cause a bearing to go. I wouldn't think you would need a new prop?!
Thx MM, that sounds easier on the pocket as the bearing and doughnut come to about £180 plus a couple of hrs labour for those of us who cant hold a spanner!
cheers
Anybody got an illustration of the prop / doughnut / bearing so I can see what it looks like? I don't fancy spending £800 or more not knowing what I'm buying (I will go and have a look when it's under surgery).
Doughnut and bearing combined is just shy of £200
Add to that a prop shaft and it's another £600 - is the prop likely to have been damaged as well as the do-nut?
I'm not happy with this one, especially considering low miles of 40k. :headbang: :
Eye ay appy! :thumbsdown:
Cheers Mike :thumbsup:
Looks like the driveshaft doughnuts off an original Lotus Elan dating back to the 1960's!!! No wonder they fail.....
Mike
Have you got same info / part numbers / prices for the prop as well. Sorry!! :driving:
Thanks :thumbsup:
Mike
Your efficiency is German-like, oh sorry that means you will fail at 40,000 miles like my prop - ha - sorry - appreciate your help again.
One on eBay currently for £100 - used - might be the same as mine but might be a good buy?
And here's the E85 for the doughnut and bearing part no's
As you can see, the doughnut and "centreing sleeve" are the same part no's.
Mike
Mike, et al,
Prop fixed with full replacement from a breaker - great service from FABDirect. Came with mint doughnut, very good centre bearing and generally a prop that looked in better, cleaner condition than mine. Next day service and very competitive too.
Talking of my old propshaft it was the centre mount and bearing / more to the point lack of bearing meaning my prop could do a merry dance with little or no support. Fixed by a good friend and mechanic this afternoon for a coffee next week! A good friend indeed :thumbsup: :thumbsup: :thumbsup:
Mike, thanks for your diagrams - I might order a centre bearing to have a good prop as a spare / avail for others on the forum if required.... :driving:
