Project Z4! [Updated: 25/06/17] (Picture Heavy)
IAmOrion
 Cambridge, UK
Hi there,
I'm both new to the forum and new to Z4's. My intro was here: http://www.z4-forum.com/forum/viewtopic.php?f=11&t=97728
Long story short, I bought a 2003 3.0i Z4, 71k miles for £1500 as a project car come doer-upper. Roof didn't work when I bought it.
Since I'm doing a few things as I progress I figured I'd write a post abit like a diary so I will over time be adding to this first post as I go.
I'll start with how the car looked when I bought it:
Stupidly I didn't take any pics of the interior before I started, but it has the cream interior which is filthy!! It also has the (IMO) horrible brushed metal trim.
So, when I bought the car, the roof wasn't working. After some investigating I had a two-fold issue whereby the microswitch was dodgy AND the top roof motor that controls the latches was buggered. I didn't take pics (I know, bad start!!) of that either, but that was about an hours job. Mostly because the bolts were f*****g tight!!! But swapped it out, and roof is now working :)
The first thing I wanted to sort out was the horrible wheels! I was going to get them refurbished but then came across a freshly refurb'd set, complete with new tires so made more sense to buy them, and just sell the ones I had on it.
They arrived today, got them fitted and I personally think they look awesome! (Just need to wash and polish the car to match)
Here's what they look like fitted:
The next thing was I wanted to fit my Double Din Pioneer SPH-DA120. Let's not debate who prefers single or double, or that it doesn't match the car... it's personal preference & I wanted double din :)
So first thing was to start designing something so that I could 3D Print a fascia.
The thread for the design progress is here: http://www.z4-forum.com/forum/viewtopic.php?f=2&t=97733
Whilst I'm still working on the design and getting things lined up etc, I decided today that I would investigate any mods that would be needed in the car to fit the new double din.
So, off the bat it was obvious there wouldn't be enough depth for a double din due to the vents. That means it's cutting time!!
Eventually, after an annoying 10 mins I managed to chop out this block...
I'm fortunate in that I have the sat nav set up - this meant I could get to the vent to chop it back easier than if I'd had to go in from the front with a dremel.
After chopping the vent back, I'm now left with enough depth to fit the head unit!
Update 1: 17th June 2017
Today I decided to try my hand at vinyl wrapping! I've never attempted this before in my life so this was to be an experience. A quick look at a couple of youtube vids & I was ready to go.
I bought myself some 6D Carbon Fibre vinyl wrap from eBay: www.ebay.co.uk/itm/381117191869 - It arrive today so I got to work
Door handles:
Switch(es):
And of course the main trim:
Before:
After:
The pictures don't do the finish justice! They look awesome (IMO) in the carbon wrap! I'm very happy with results
to be done tomorrow!
Update 2: 19th June 2017
Like an idiot, I leant on the heat gun when reaching across the table ha!
Anyway, finished my wrapping and got the bits installed this morning. Here's the final result:
You will have to excuse my crappy photo skills. As you can see I did the door handles, the window switches, the center console, and main dash trim.
Anyone considering wrapping for the first time, I'm gonna say give it a go. My results aren't perfect as this was my first time however, I am still happy with results enough to refit the parts :)
This was the main youtube video I watched to get an idea on what to do: www.youtube.com/watch?v=hRUvucGdJ_c
Update 3: 25th June 2017
Another update now, so I went and collected my replacement passenger side front wing. Changing the wing was a mission and a bloody half let me tell you!! The changing of the wing itself is actually fairly straight forward - but I had 3 seized bolts :( All of which the torx head appeared to be already rounded!!! So out came the dremel to cut a nice slot in the middle to get a large flat headed screw driver into. With no joys there, I used a pair of vice grips clamped to the side of the screw driver handle - forming a kind of T piece, but on one side only. So an inverted L I guess. Anywhere with lots of abuse & cursing I FINALLY managed to get them all off.
First of all, you need to take the side skirt off. This is fairly easy. I had 2 x 8mm nuts and lots of plastic expanding retaining rivets. I would say it's worth spending a few £ and getting a pack of these: http://www.ebay.co.uk/itm/20x-BMW-Expanding-Rivets-Plastic-Trim-Clips-for-bumpers-sills-skirts-covers/370931120194 because those b*****ds can be a pain to get out and I found most broke or just squished too much. And for the sake of a few £ I felt better putting new ones back in place. Once they're out of the underside of the side skirt, it literally just pulls off. I went gently from back to front and came off with reasonably light effort. Wing next....
There's 3 x T30 torx screws along the top, and a 10mm nut just beyond the bonnets end, infront of the windscreen:
There's 2 x 8mm bolts in the wheel liner, 1 x T30 Torx on the INSIDE of the door
and then 2 x T30 on the INSIDE of the wing itself. They were not fun to get to - especially when one of the 2 was amongst the ones pre-rounded! Getting a dremel into that space was a right PITA.
TOP:
BOTTOM:
Got there in the end though!
Next on the list was putting my rear top plastic cover back on. The manual roof release was missing a spring and so the handle sat wonky. I didn't like this! I took it when I was wrapping my center console, but only just got around to sorting a spring. Once I'd made a make shift spring by destroying a clothes peg, I realised that one of the hooks had actually broken. It was held on by luck I think, but only took me 30 seconds of trying to glue it for it to fall off!! :headbang: :cry:
Well, that's there the 3D Printing comes in handy again 8) Measure the hook, drew it up in 123D Design, printed it, then used JB Weld Plastic Bonder Epoxy to glue it in place. Works perfectly now, woohoo!!
(I might have gone a little overboard with the epoxy! :roll: )
I borrowed a spring clip from the - whatever it's called - center / arm rest that's not an arm rest cover thing to test with, perfect-a-mondo
The last update for now, was replacing the side markers for clear ones, and changing the badges. I am changing the badges all around and will add photos in the next few days. For now though, here are the pics of the side marker side by side...
New on "top" and old on "bottom"
In case you're wondering, I bought my clear side marker/indicator from bmw_direct on eBay for £21.80. I only bought the one, as the side wing I bought came with one already as it was off a 2006 model.
http://www.ebay.co.uk/itm/BMW-Genuine-Additional-Turn-Signal-Indicator-Lamp-Light-White-63137165734/172364896177
Then it was back to working on the Double Din Fascia...
More details of which are in my "Double Din Fascia" thread http://www.z4-forum.com/forum/viewtopic.php?f=2&t=97733
Nice going dude, will be interesting to see how it all looks when reassembled. wheels look good too :thumbsup: :thumbsup:
Thanks :) Yeah I'll update the post with pics with pics etc once it's all put back together. Tomorrows task is trying to get the center console out to wrap that!! Then it can all go back in and I'll get pics
Love following hands on progress threads like this, lots of info and photos means it's easy for people like me to pluck up the courage to give it a go myself!
Especially the wrap, recently got the folding mirrors off machine monkey so will probs have to take the interior apart to fit some wires so would make sense to do cruise at same time (if I can find 1 in time) and wrap all interior panels at same time whilst it's apart!
Great work!
Great work!
Thanks :D I thought I'd write it as I went along so others can read my progress and maybe decide to give something a go on their own, or just enjoy the read! More to come once I have time to fit my passenger wing and also finalise my double din fascia. I'm also trying to design something I can insert into the cut fan duct to redirect air either side of the stereo fascia I'm making
Really good work, my mate did the carbon wrap in his 335i and made a massive difference. Yours looks great and brought it up to date in my eyes...I never liked the silver in my Zed
Yeah that brushed aluminium, IMO, is bloody awful!!
Very nice! I like what you've done and will continue to follow with interest!
What are your next plans, double din aside? :)
That wing had been off before for sure as one of the bolts was in the wrong way.
The top and bottom bolt in the door pillar should be removed from the pillar side. Only the middle one should be accessed from within the wing.
You confused me a little there!
I swear I read in one of your posts there was only 1 "outside" the wing in the door pillar?
It wouldn't surprise me that Wing having been removed before - I think the car was pretty abused before I got it lol
I'd have to double check. Easy enouh to do, just need to open the door :lol:
You might want to check your drivers side.
My "what's left to do" list is:
A areas to touch up with a touch up pen. I'm not too fussed about making it perfect everywhere - it is a 14 year old car after all, so the few little scrapes I will touch up
Proper valet type service inside and out - it needs a bloody good clean inside & out !!
Aero Spoiler
Custom Headlights.... this is currently in the R&D stage. I've previously made custom lights for my old Saab & a few motorbikes. I realise these lights are a b*****d since they're cut and shut and you can't bake them - but I'll worry about that when I get to that stage. Will probs be in a month or so with everything else I've got going on atm
