proflex poly bushes
domsz4
Veteran
so i received my flo flex poly bushes while i was away, they certainly look chunky enough but how do you fit them?
i expected them to be 2 pieces that clamp around the bar but they are 1 solid lump? are you supposed to slide them on from the end?
Domsz4
Look in the how too's I did a write up. I had floflex you have to cut them. Bottom side.
Second part of the write up
http://www.z4-forum.com/forum/viewtopic.php?f=24&t=46749
Pretty straight forward.
thanks ... guessed as much ... id looked at that write up before just not paid enough attention to the text.
i was thinking it was going to take some serious lube to get them round the bends in the bar :o :?
Yes I don't think there's enough KY in the world to achieve that. :lol:
I had to ring Floflex because I was a little puzzled too . They said the don't cut them as certain applications don't require it, so leave it up to the purchaser.
